Coach power
Dougiefrsh1
There is another possibility, inside of your converter there is a relay here is what happens. When you are plugged in the relay closes and disconnects the battery from the coach the converter then charges the battery and supplies 12 volts to the coach it is possible the relay sticking in the on position when you unplug this is not an uncommon problem so even with a fully charged battery it has no way back into the coach electrical system. You might try giving the converter a good wack with your hand this sometimes frees the relay. Inside the converter there is a fuse panel there should two large lugs between the two with the camper unplugged there should be 12 volts if not there is a poor or disconnected lead to the battery if that's not the case then the relay is stuck on. Be advised when playing with this system the relay is energized with deadly voltages from the power cord so caution is of the utmost.
