Bigdog
Noise from electrical box
All of a sudden after being plugged in with land line I moved and came back to same location two hours latter and plugged in again
and now ever few seconds I get a ping then a pong sound from the back of the breaker box were the land line is connected?
What happens to the lights when it pings.
Sorts sounds like an auto reset CB, that maybe part of the 12 v charge system.
Haven't used lights but TV goes off and on plugged into inverter
12 volt lights dim and brighten in unison with noise. how do I correct?
Again an auto reset CB.  MAYBE its between the battery and charger. Your voltage is going between 13.5v, cb on and 12.5 v cb tripped. Again MAYBE a bad cb or there is a shorted wire some where. Time to get the ol' eyeball working.
Your coach battery connected properly? Sounds like the cables are reversed.
what is a CB
