huxz Posted March 23, 2008 Share Posted March 23, 2008 This is my first or second posting if the first one worked. I just got an 1985 Toyota Huntsman RV. It came with anconverter according to the brochure. Does anyone know where it is located and how to operate it? Thanks Huzx Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 23, 2008 Share Posted March 23, 2008 Mine is behind a cabinet door in the coach. It usually has the 120 volt breakers in it and a 12 volt fuse panel of some nature. They pretty much work by them self’s, if you plug the camper in it will make 12 volt from the mains for your lights and charge the battery. Be advised if it is the original they make pretty poor battery chargers and will boil the water out of your battery if you leave it plugged in all the time. Quote Link to comment Share on other sites More sharing options...
huxz Posted March 24, 2008 Author Share Posted March 24, 2008 Thanks, I will have to check it out tommarrow, I found the manuals and it was a standard item on the RV it just does'nt say anything about where and how to use it. Huxz Quote Link to comment Share on other sites More sharing options...
