ALOT of the wires under the hood are messed up. PO ran 14/2 with ground Romex from the alternator to the harness.  Some are OK and some have been spliced up badly.  Question....
What years would I be able to use on our 76 toy?
I found an 82 Toyota in a field that the owner started to put in a Chevy 283 but had not touched the wire harness yet. Would this work or would it need a little, some, or a lot  of work to make work correctly?
I do know the 82 is a 2 headlight and ours is a 4 headlight. That is an easy fix.
Thank you.
Check "Rock Auto". There are wiring harness replacement kit. "Painless wiring" will have or can make a harness. Why take a chance using 40 year old wires.
