Baseball Dad Posted September 23, 2016 Share Posted September 23, 2016 Has anybody ever use sikaflex to seal around there RV ? Quote Link to comment Share on other sites More sharing options...
Back East Don Posted September 23, 2016 Share Posted September 23, 2016 2 hours ago, Baseball Dad said: Has anybody ever use sikaflex to seal around there RV ? Which one? I tried to look up the material data sheet and there is a variety of products. Which one is designed with a lot of flex for an RV application? Quote Link to comment Share on other sites More sharing options...
zulandio Posted September 23, 2016 Share Posted September 23, 2016 I just used eternabond tape on mine 50 feet was enough to do all the roof edges about 3 inches down in back, the front and rear seal on the roof, and all the way down the cabover. I pulled the channel cover out since it was cracked and leaking. It flexes and sticks for up to 35 years if done right. It can be taken off with a blow drier if needed. Quote Link to comment Share on other sites More sharing options...
Baseball Dad Posted September 23, 2016 Author Share Posted September 23, 2016 the one i started to seal the cargo area is Sikaflex construction sealant.For around the front and back seal I ordered Seal tite Corner tape 1 1/2".let me know what you guys think.Oh I was wondering what glazing seal would you use for the windows? Quote Link to comment Share on other sites More sharing options...
jjrbus Posted September 23, 2016 Share Posted September 23, 2016 JD is using OSI Quad for caulking, I looked it over and am using it also. Not an easy water clean up product so care is needed when applying! http://www.homedepot.com/p/OSI-10-fl-oz-White-No-001-QUAD-Advanced-Formula-Window-Door-and-Siding-Sealant-VOC-1642487/203357966 Most things that attach to the RV should use Butyl rubber putty tape. If you try to stretch it and it quckily breaks it is not butyl rubber. I have Toyed with different tapes and would stick with Eternaond unless someone has something better? For flat roof areas, a self leveling is best, I have no recommendations on it, I used Dicor self leveling as it was quickly available. HTH Jim Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted September 23, 2016 Share Posted September 23, 2016 I have completely sealed all areas that are not flat with Flexseal by Geoseal. On the roof I used Dicor self leveling caulking and Eternabond tape and as Jim said Butyl tape. When restoring my 85 Granville, I found the Butyl tape that was underneath stuff that I was resealing was still in perfect condition! Make sure when you buy Butyl tape that it stretches like bubblegum or it's not Butyl tape like Linda states. Quote Link to comment Share on other sites More sharing options...
