d.richey Posted January 19, 2008 Share Posted January 19, 2008 There is nothing in my manuals about using overdrive or overdrive/off for my v-6 92 Warrior. I could not find anything at the forum using search. Could I get some specifics about its use: just hills?, what speeds? etc.Doug 92 Warrior v-6 Quote Link to comment Share on other sites More sharing options...
Shoprat Posted January 23, 2008 Share Posted January 23, 2008 I was hoping that someone with newer Toys would reply to this, but I'll stick in my 2 cents worth. I use my overdrive on the flat and in gentle, not too frequent, hill areas. Mine shifts into overdrive at about 57 - 59 miles per hour. I feel it shift into overdrive, then back off the speed a tad and cruise just below 60 miles per hour. I remember reading one time that a wind wall developes in front of a vehicle at 60 mph and increases the wind resistance about four times that at 55 mph. So. I decided to just cruise at about 57 to 59 mph as a good compromise of miles traveled per day and still keep decent gas mileage. The overdrive helps gas mileage a good bit, but in mountains and frequent hills , the constant shifting in and out of overdrive does not do the tranny longetiveity much good. A tranny repair is expensive and will far surpass the money saved in gas mileage by using overdrive excessively. When in doubt, don't . Thats my thoughts. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted January 27, 2008 Share Posted January 27, 2008 There is nothing in my manuals about using overdrive or overdrive/off for my v-6 92 Warrior. I could not find anything at the forum using search. Could I get some specifics about its use: just hills?, what speeds? etc.Doug 92 Warrior v-6 my 91 itasco spirit (same as winne warrior) has a toyota owners manaul - it says to turn it off if the vehicle is shifting in and out of OD - like when operating on hills or when towing. There are no speed recommendations otherwise. I would leave engaged otherwise. I also noted that they recommended using "2" and (if even slower) "L" going down hill (for engine braking) but to use "d" for uphill. There are speed recommendations for 2 & L. I have read in other posts that some have reported that when operating above (It think it was) 3,000 ft elevation that OD would not work - someone said there is a barimetric device that locks the OD out. Others had reported that it would quit going up and work again when lower. Quote Link to comment Share on other sites More sharing options...
