Bigdog Posted October 12, 2015 Share Posted October 12, 2015 1985 Sunrader with 1991 1-ton axle need info again? Quote Link to comment Share on other sites More sharing options...
linda s Posted October 12, 2015 Share Posted October 12, 2015 Here's the part http://www.shockwarehouse.com/site/product.cfm/id/288103/name/57113-Airlift-Super-Duty-Air-Spring-Kit-Toyota-Motorhome And here's a 50 dollar rebate https://www.airliftcompany.com/support/rebates/ Linda Quote Link to comment Share on other sites More sharing options...
Bigdog Posted December 1, 2015 Author Share Posted December 1, 2015 Went to order kit# 57113 found out it is for front Kit #59502 is for rear, max is 2000 Is this the best I can get? Didn't seem like enough for my load and old springs? Quote Link to comment Share on other sites More sharing options...
linda s Posted December 2, 2015 Share Posted December 2, 2015 They made a mistake on their website. There is no kit for the front. Look here, same kit and it says rear http://www.amazon.com/57113-LoadLifter-Series-Spring-Leveling/dp/B001G92P4S Use the part number to search. You can find cheaper prices. Linda S This is a 5000lb leveling system Quote Link to comment Share on other sites More sharing options...
Bigdog Posted December 4, 2015 Author Share Posted December 4, 2015 Thanks Linda, Ordered kit then was notified it may require drilling of frame, my mechanic that was going to do the install can't or won't drill frame, so know i have two repair problems I don't have the ability to do the work myself, also I'm having the ty rods and other steering components replaced, and also need the rear spring bushings replaced. so I need a mechanic to do the air spring and bushing install, and find a shop that can do an alignment of the front end. if any one can give me recommendations for the L A ,Orange county area it will be greatly appreciated. Bigdog Quote Link to comment Share on other sites More sharing options...
zero Posted December 4, 2015 Share Posted December 4, 2015 my mechanic that was going to do the install can't or won't drill frame, so know i have two repair problems I don't have the ability to do the work myself, Bigdog Toyota gives clear instructions in the cab & chassis manual on where you can safely drill the frame. I think they also give the same info in the standard truck manual. If you trust your mechanic to be competent - ask him what his/her issue is? It certainly is not a frame-integrity problem. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 4, 2015 Share Posted December 4, 2015 Somehow, I doubt your kit supplier would give instructions to drill the frame if it wasn't safe to do so. Too many hungry lawyer on your side of the border to risk it. Quote Link to comment Share on other sites More sharing options...
Bigdog Posted December 5, 2015 Author Share Posted December 5, 2015 Where can I find the manual. Bigdog Quote Link to comment Share on other sites More sharing options...
zero Posted December 5, 2015 Share Posted December 5, 2015 Here are some info directly from the Toyota truck&chassis manual. Also from the Airlift installation manual. Quote Link to comment Share on other sites More sharing options...
