MontanaChinook Posted February 12, 2015 Share Posted February 12, 2015 About 10,000 miles after I replaced my oil pump, it started leaking a bit. Either that or my front main started leaking...but we'll see. I'm just assuming oil pump for now. So I ordered a new o-ring for it. One of the top bolts needs thread sealant applied to it. I want to do this before I hit the road in March. That means that at best I might have 40-degree temps, but more likely 20s or 30s. Will the sealant set up in those kind of temperatures? Quote Link to comment Share on other sites More sharing options...
Totem Posted February 12, 2015 Share Posted February 12, 2015 red or blue, i would say no. put a space heater on it. Quote Link to comment Share on other sites More sharing options...
zero Posted February 12, 2015 Share Posted February 12, 2015 So I ordered a new o-ring for it. One of the top bolts needs thread sealant applied to it. I want to do this before I hit the road in March. That means that at best I might have 40-degree temps, but more likely 20s or 30s. Will the sealant set up in those kind of temperatures? Non-hardening thread sealant is what is usually used on bolt-threads. There is no temperature range in the real world where it cannot be used. Something like Permatex "Thread Sealant with PTFE" remains pliable down to 50 below 0 F. RVS sealants are different and not what you want on bolt threads anyway. As the "RTV" name implies, it stands fo "room temperature vulcanizing." Not supposed to used below 35 degrees F unless you warm things up. We had to use RTV often, outdoors on forestry equipment sometimes at 0 F temps. During those conditions, you heat the metal and the tube of RTV before applying and then try to keep heat on the joint for awhile. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted February 12, 2015 Author Share Posted February 12, 2015 Yep, thread sealant, not RTV. Ok, thanks. Quote Link to comment Share on other sites More sharing options...
kgibson4 Posted February 12, 2015 Share Posted February 12, 2015 Some people reading this thread may not realize that thread sealant is not the same as thread locker. Just wanted to point that out. Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 13, 2015 Share Posted February 13, 2015 Why do you need it in the first place? There is no need for sealant on the pump housing and it may even make it worse. If the bolt is loose there is some thing wrong with the threads. It is a common problem with those engines it is a lot easier to remove the pump to replace the front seal so a new "O" is in order any way. Quote Link to comment Share on other sites More sharing options...
Totem Posted February 13, 2015 Share Posted February 13, 2015 my bad thought he was talking about thread locker which wont set in cold. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted February 13, 2015 Author Share Posted February 13, 2015 And I quote myself "one of the top bolts needs thread sealant" and "I ordered a new o-ring for it" Quote Link to comment Share on other sites More sharing options...
zero Posted February 13, 2015 Share Posted February 13, 2015 Same as shown in both my factory manuals. Quote Link to comment Share on other sites More sharing options...
