loria.edgar Posted January 10, 2015 Share Posted January 10, 2015 I have a Toyota Odyssey 1990. I need to buy an awning. I guess 12-13 feet for the side, !! and which one or what type is the recommended? Also a replacement fridge and A/C? Can somebody tell me a web side to buy them? Thanks Edgar Quote Link to comment Share on other sites More sharing options...
Skydancer2992 Posted January 10, 2015 Share Posted January 10, 2015 The Bottomdollarsurplus ebay seller has them every few weeks. Usually cheap, like $30. They have also sold AC units rather inexpensively, like $250. Quote Link to comment Share on other sites More sharing options...
loria.edgar Posted January 10, 2015 Author Share Posted January 10, 2015 The Bottomdollarsurplus ebay seller has them every few weeks. Usually cheap, like $30. They have also sold AC units rather inexpensively, like $250. Thanks!! Quote Link to comment Share on other sites More sharing options...
Vanman Posted January 10, 2015 Share Posted January 10, 2015 We have the kind that has an aluminum pleated cover plates. Just roll it up and it's protected from the elements. Ours is old, but when you roll it out looks like new. Cost more but really worth it in my view. Quote Link to comment Share on other sites More sharing options...
jdfrost64 Posted January 10, 2015 Share Posted January 10, 2015 I have a roof air that I'm not going to put back on mine .if interested let me know Quote Link to comment Share on other sites More sharing options...
loria.edgar Posted January 12, 2015 Author Share Posted January 12, 2015 We have the kind that has an aluminum pleated cover plates. Just roll it up and it's protected from the elements. Ours is old, but when you roll it out looks like new. Cost more but really worth it in my view. Where I can Buy it? what is the brand, style..?? Thanks Quote Link to comment Share on other sites More sharing options...
Vanman Posted January 13, 2015 Share Posted January 13, 2015 It's a Dometic, will try to find model #. It's a 2 way in the sense you can extend the vertical arms and leave them attached to the bottom of the RV or detach them and run them straight down, the feet have holes for the tent stakes. Either way ours is not as stable as I like things to be I went to a Ben Franklin and got, 2 4 packs of stakes, stake hammer with removal claw, and 50' of 1/4 nylon rope. Burn rope in center to get 2 25' lengths. Run each rope around the top ends of the extended awning, one or two wraps, and run to the ground, (at a 45 degree angle), and stake each end. Even if you get a windstorm (which we did get at Burney Falls) no problems. It says A&E Systems on the bottom of both vertical struts. I measured it at 12 feet, which is as long as you could put on ours. I have had it well over 6 feet extended, don't know how long it goes. Quote Link to comment Share on other sites More sharing options...
mission mike Posted January 13, 2015 Share Posted January 13, 2015 http://www.dasmule.com/arb-awning-3-sizes/ I'm considering one of these awnings, I believe they were made for VW vans? but look like they would easily adapt to fit our motorhomes. Price would be under $400 for the 8ft x 8ft size. Mike Quote Link to comment Share on other sites More sharing options...
canman47 Posted January 14, 2015 Share Posted January 14, 2015 Mike, I like the design of those awnings but I wonder how they attach to the vehicle. It would be nice if they use the awning rail that is on most RV's. I don't like drilling more holes. Quote Link to comment Share on other sites More sharing options...
