trickofthetale Posted October 17, 2014 Share Posted October 17, 2014 The cabin battery has a three position switch. One is off one is battery, and the third is for ? And when should it be on. Is that to charge the battery while I drive? should I also have it on when I am plugged in and parked. Vehicle runs great I just don't want to screw anything up. I have the older 3 stage fridge manual should anybody need info Quote Link to comment Share on other sites More sharing options...
zero Posted October 17, 2014 Share Posted October 17, 2014 The cabin battery has a three position switch. One is off one is battery, and the third is for ? And when should it be on. Is that to charge the battery while I drive? should I also have it on when I am plugged in and parked. Vehicle runs great I just don't want to screw anything up. I have the older 3 stage fridge manual should anybody need info Any mechanical rotary battery switch I've seen with three positions is meant to be used with two inputs from two different battery banks. Bank 1, OFF, and Bank 2. But I have no idea what sort of switch has been put in your RV. Quote Link to comment Share on other sites More sharing options...
Maineah Posted October 17, 2014 Share Posted October 17, 2014 Sounds like a boat duel battery switch. You have two batteries in the coach? Quote Link to comment Share on other sites More sharing options...
