FredNewell Posted May 30, 2014 Share Posted May 30, 2014 Right turn signal position has begun to click twice as fast. I am thinking the flasher is needing replaced. Anyone know where it is located? 84 chassis. all signals operate as they should for now... Just blinks faster for rt turn. Thanks. Quote Link to comment Share on other sites More sharing options...
Sunnynshare Posted May 30, 2014 Share Posted May 30, 2014 Probably one of the lights is burned out. Kim Quote Link to comment Share on other sites More sharing options...
snail powered Posted May 30, 2014 Share Posted May 30, 2014 That blinks twice as fast does indicate a burned out bulb. Inadvertent safety feature! Quote Link to comment Share on other sites More sharing options...
Vanman Posted May 30, 2014 Share Posted May 30, 2014 OR more noticable with LED lamps, they turn on and off much faster than the bulb does. I like the fast flash I have now. john / mary Quote Link to comment Share on other sites More sharing options...
Derek up North Posted May 31, 2014 Share Posted May 31, 2014 That blinks twice as fast does indicate a burned out bulb. Inadvertent safety feature! Maybe not so inadvertent. "It is also required that the vehicle operator be alerted by much faster- or slower-than-normal flashing in the event a turn signal light fails." http://en.wikipedia.org/wiki/Automotive_lighting Quote Link to comment Share on other sites More sharing options...
zero Posted May 31, 2014 Share Posted May 31, 2014 Maybe not so inadvertent. "It is also required that the vehicle operator be alerted by much faster- or slower-than-normal flashing in the event a turn signal light fails." http://en.wikipedia.org/wiki/Automotive_lighting Any change in amp-draw changes the blink-rate IF it's the correct flasher and mechanical with the thermal bi-metal trip. . Thus the issues with LED replacements or with so-called "HD flashers." I see many people with LEDs are using electronic flashers with adjustable blink rate. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted June 3, 2014 Share Posted June 3, 2014 Yes, with every vehicle I've ever had, a faster blinking blinker means the bulb is going out. Quote Link to comment Share on other sites More sharing options...
FredNewell Posted June 3, 2014 Author Share Posted June 3, 2014 Interesting, and I learned something new. I had a 79 Cordoba. When the brake light burned out, the interior dome light came on if you depressed the brake pedal. Quote Link to comment Share on other sites More sharing options...
MontanaChinook Posted June 3, 2014 Share Posted June 3, 2014 Ha Quote Link to comment Share on other sites More sharing options...
