nooga Posted December 10, 2013 Share Posted December 10, 2013 the side house door on my 1994 Itasca Spirit rattles to beat the band while driving down the road. Is there any easy way to tighten it up w/o taking entire door off or replacing it? Would appreciate any suggestions. I realize that motorhomes and rattles cannot be entirely separated but this rattle is excessive. nooga Quote Link to comment Share on other sites More sharing options...
WME Posted December 10, 2013 Share Posted December 10, 2013 A couple of choices. See if the door striker can be adjusted. Its the part on the door frame, not the door. Get some foam weather strip and redo the door weather strip. Quote Link to comment Share on other sites More sharing options...
waiter Posted December 10, 2013 Share Posted December 10, 2013 ^^ I did the same, 3/8 foam self adhesive strip around the door frame. Shut that noise up.JOhn Mc Quote Link to comment Share on other sites More sharing options...
Vanman Posted December 11, 2013 Share Posted December 11, 2013 Mine is like that cause the door in not flat anymore. I found I had to use the thicker solid rubber strip insulation, even doubled up at the bottom. Use the same on the other side of the door where it hits the rv so when you open it there's no damage to the side of the RV. john Quote Link to comment Share on other sites More sharing options...
nooga Posted December 11, 2013 Author Share Posted December 11, 2013 Thanks for the helpful hints. Will check the latch and invest in some weather stripping. nooga Quote Link to comment Share on other sites More sharing options...
