Tressa Posted November 2, 2013 Share Posted November 2, 2013 My Convertor went out this summer on my 1986 New Horizon. What do you do when you are in the boondocks and your house lights go out? Always be prepared! Things happen. It is called Murphy's law. 1. Buy at least a 400 watt inverter: It plugs onto your coach battery with cables. It works for lights and for your lap top too. I have a white extension cord I stick through the window to plug into the inverter. A little tacky but it works. 2. Buy a small lamp with minimum wattage or buy florescent lights to plug into your inverter! If your coach lights go out you still have light. 3. Have a package of small tea light candles on board. It is amazing how 3 small candles light up the darkness and add romantic ambiance. We are so far removed from candle light. Did you know you can use olive oil to make a oil lamp? Take a piece of string, a paperclip, a small jar, and little olive oil and light it. It burns clean. 4. Have a few flashlights handy with fresh batteries. Put them in a place where you can find them in the dark. In any case it is always good to be prepared! Quote Link to comment Share on other sites More sharing options...
Gary_M Posted November 2, 2013 Share Posted November 2, 2013 Take a string and put in a can of Crisco. That will last about a month. ;-) Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 2, 2013 Share Posted November 2, 2013 My Convertor went out this summer on my 1986 New Horizon. What do you do when you are in the boondocks and your house lights go out? Always be prepared! Things happen. It is called Murphy's law. 1. Buy at least a 400 watt inverter: It plugs onto your coach battery with cables. It works for lights and for your lap top too. I have a white extension cord I stick through the window to plug into the inverter. A little tacky but it works. 2. Buy a small lamp with minimum wattage or buy florescent lights to plug into your inverter! If your coach lights go out you still have light. 3. Have a package of small tea light candles on board. It is amazing how 3 small candles light up the darkness and add romantic ambiance. We are so far removed from candle light. Did you know you can use olive oil to make a oil lamp? Take a piece of string, a paperclip, a small jar, and little olive oil and light it. It burns clean. 4. Have a few flashlights handy with fresh batteries. Put them in a place where you can find them in the dark. In any case it is always good to be prepared! Or buy a modern converter that has no relays! Better yet just go to bed and worry about it in the morning! Quote Link to comment Share on other sites More sharing options...
