smokepolehall Posted July 23, 2007 Share Posted July 23, 2007 Well i got a 4' stick of 18ga. perforated galv. angle. I have cut couple of short lengths off of it. Plus i have couple of L brackets. Will use them for new ply supports. Have to drill about 6 more holes here and there and bolt support frame together. Then i will cut ply and install as step. Quote Link to comment Share on other sites More sharing options...
turtle Posted July 24, 2007 Share Posted July 24, 2007 Well i got a 4' stick of 18ga. perforated galv. angle. I have cut couple of short lengths off of it. Plus i have couple of L brackets. Will use them for new ply supports. Have to drill about 6 more holes here and there and bolt support frame together. Then i will cut ply and install as step. I hope that you are taking photos of all this work Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 24, 2007 Author Share Posted July 24, 2007 I am trying to, will take a pic of the area step was in and when i get angle put in. Don't have a welder, that would be so much easier. i will have to bolt in all together. Such is life, don't cha love it! Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 25, 2007 Author Share Posted July 25, 2007 I did manage to measure and cut and install both sides to step and the kickwall. Soon as i can cut bottom part of step and put it in, i will put the perforated 1 1/4"x 1 1/4" angle for support. The passenger wall where entry door is. Has seperated and is 7/8" wider at door handle side than at hinged side. I will have to use high-lift jack to push bottom of door back into square then bolt up angle support. Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 26, 2007 Author Share Posted July 26, 2007 I got the bottom step measured and cutout. then i cutout another matching piece. Now its 1" thick and put on 4 L brackets. Got too hot after noon so i came inside to suck up cool air. I'll get back to it tomorrow. Have to cut an acre yard later today. Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 27, 2007 Author Share Posted July 27, 2007 Don't have a 2' wood clamp, to hold step up to to attach L brackets. So i measured width and made a push on clamp. Made just abit tight and will tap it on with hammer. Then see if i can finish this project up. Then i will start on next repair project. Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 28, 2007 Author Share Posted July 28, 2007 I tell ya there is always a dime holding up a hundred dollars! I don't have enough room to drill holes to bolt on angle supports. So i jacked up Odd Duck and took duals off on passerger side. Put 2 jacks under plus leveling jack in rear is down. I am just too old to take a chance. So i waited until i got some coins, will go to town and buy a set of 3 ton jack stands. Then i can drill the holes and not worry about close to 2 tons coming down on top of me! I want to go camping not take a dirt nap! Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 28, 2007 Author Share Posted July 28, 2007 This has been one of those days friends! I went and got pair of 3 ton jack stands and i got them under the Odd Duck. Took one of the jacks out so i have room under there to drill the holes. I had to stop at that point as it started to sprinkle. I had to hurry and put my tools up. Had to put up lawnmower and air compressor. Well tomorrow is a new day. Quote Link to comment Share on other sites More sharing options...
WME Posted July 29, 2007 Share Posted July 29, 2007 Know the feeling I had to repair a gray tank in the rain. Had to much spread out to quit. Quote Link to comment Share on other sites More sharing options...
turtle Posted July 29, 2007 Share Posted July 29, 2007 Know the feeling I had to repair a gray tank in the rain. Had to much spread out to quit. Had a "non announced" rain storm yesterday afternoon (started raining with the sun shining). I had finished the last layer of fiberglass mat in the morning and wanted to let it bake in the sun before covering it up. Needless to say nothing covered up by shower time. I did stick a 4x8 sheet of foam insulation board over the open roof and shower vents to keep rain from coming inside. Got about 3/4" of rain out of the storm. The fiberglass held up wonderfully (as it should) and only a single drop came in around the cardboard "plug" I put in the roof vent to keep the resin from dripping inside. Must be my lucky day Walked around on the roof today after drying it off and it is sold as a rock after 4 layers of 1.5 oz chopped mat fiberglass and 1 layer of woven cloth. I didn't jump up and down on it as it is still on axle stands in the back (waiting for the replacement shocks). Tomorrow will be touch up with tiger hair and sand everything to apply the gel coat. Can't wait to see it all white and shiny Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 29, 2007 Author Share Posted July 29, 2007 Glad to hear that all turned out well on roof and the rain. I got hole drilled in support, can't bolt it yet. I cleaned out all the rotted wood from under entry step. Then c clamped new wood under door drilled 5 holes and popped wood screws into wood. Put the 4 nut driver screws in. Had to take the gas cap plastic housing off, its broken. Happened during coach sinking down below the few supports. Just one thing after another. I got new wood installed under gas opening after cleaning all that rotted wood out. 2 holes in floor one above the dual wheels on passenger side. Another by converter. I will repair them,sometime later. Aug. i reckon, as i will still be cleaning rest of rotted wood out of bottom on passenger side. Its mid 90's outside so it will be later today before i bolt top of angle on support. Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 30, 2007 Author Share Posted July 30, 2007 Well after all the honey do's i didn't get much done this evening. I got all the protruding screws ends cutoff. Put up tools and air compressor, fan and boombox. Yeah i am listening Dwight Yoakum cd, might as well enjoy my music while working. Quote Link to comment Share on other sites More sharing options...
turtle Posted July 30, 2007 Share Posted July 30, 2007 Put up tools and air compressor, fan and boombox. Yeah i am listening Dwight Yoakum cd, might as well enjoy my music while working. Ya can't work with out "tunes (at least I can't)... The wife is always complaining as she says that she can't talk over it and that I don't seem to hear what she is saying (duh)... You have to have something do drown out the air compressor Quote Link to comment Share on other sites More sharing options...
smokepolehall Posted July 30, 2007 Author Share Posted July 30, 2007 I don't have mine (boombox) up load enough to drown out my Mrs. or the compressor. I have 60' air hose and 100' ext. cord heavy enough to handle it. So i put it out yonder so i don't listen to it. Quote Link to comment Share on other sites More sharing options...
