britann Posted May 26, 2013 Share Posted May 26, 2013 I need advise on the best side mirrors to install and tips for best visibility backing up etc. Thanks! Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 29, 2013 Share Posted May 29, 2013 do you have the org four head mirrers what is this on . i have had to rebuild my set up as somone removed the org set up and what was on there was no good at all need more info pict is good Quote Link to comment Share on other sites More sharing options...
Bob C Posted May 31, 2013 Share Posted May 31, 2013 I will be replacing all four of my mirrors because they are all rusted out with holes in the metal. I have decided to go with single 6 x 10 mirrors with a single mounting bolt and move them down on the original mounts. By moving them down on the mount, I will be able to look over the mirrors. I really hate that 6 x 12 blind spot on both sides. I will also be using a pair of stick on curved mirrors for the wide angle view. The 6 x 10 flat mirrors are available at O'Reily's for about $16 each. I know that it may look a little strange with the mirrors being mounted lower instead of being centered on the vertical tube but I will put up with it for the increase visibility out the side. I will post a photos when I get it done. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 31, 2013 Share Posted May 31, 2013 THANKS I NOW HAVE EXT ON THE TWO SHORT ARMS STILLHAVE THESINGLE WEST COAST TYPE HEADS ADD ED A PAIR OF CONVEX ROUND HEADS UP ON TOP . STILL DOING SOME TWEAKING BUT GETTING BETTER. SOME MORONUSED HARDWARE TURNBUCKLES FOR EXT FLOPED ALL OVER LOOKED LIKE I WONT GO THERE Quote Link to comment Share on other sites More sharing options...
