Puffp Posted May 12, 2013 Share Posted May 12, 2013 All, As you may be able to see the trim is coming off on one side and I want to redo it, the other side is ok but looks sloppy. The last photo I included because the fiberglass near the bumper and in a couple other spots is not attached to the wood underneath, not sure if that is normal or if I need to bond it together. Not sure how I would even get under there unless I took the whole fiberglass back off. So for the siding I need to remove it and then use butyl tape and some caulk? Many types of caulk and think I may go OSI. Just wanted some recommendations from those who have done this. Best, Patrick Quote Link to comment Share on other sites More sharing options...
sdboltdude Posted May 13, 2013 Share Posted May 13, 2013 Hey Patrick the most important thing is to try to reuse your old corner molding try to take off with out bending them keeping them as original in shape as you can. hopefully you can get the screws out(some screws might be rusted-out careful when pulling out you don't want to bend your corner molding.. new corner moldings are a pain n the azz to bend new ones (you will have to cut the molding to bend) then clean all the gunk off molding and rv (make sure its supper clean)and use a good silicon.. I like 3m (I used 3m 5200 marine grade) I had to use a gas rag to get clean (CAREFUL BOOM!!!) they also make a good uv silicon... your bottom siding is coming off because water has ate away your screws when corner molding is off you might want to look at how bad water damage is if not to bad you might be able to gorilla glue fiberglass back to rv frame.. Quote Link to comment Share on other sites More sharing options...
Puffp Posted May 13, 2013 Author Share Posted May 13, 2013 Thanks for the info. I think I read a couple of posts of your where you were doing the same thing, but needed new siding. Anways I will plan on giving it a go soon. Best, P Quote Link to comment Share on other sites More sharing options...
sdboltdude Posted May 14, 2013 Share Posted May 14, 2013 yes that's me my siding was shot last owner used bondo to quick fix I had to replace mine good luck on project!! post more pics when doing job.. Thanks for the info. I think I read a couple of posts of your where you were doing the same thing, but needed new siding. Anways I will plan on giving it a go soon. Best, P Quote Link to comment Share on other sites More sharing options...
