futar Posted September 2, 2012 Share Posted September 2, 2012 Does anyone Have a schematic of a 91 Winnebago metal coach frame? Thanks Quote Link to comment Share on other sites More sharing options...
linda s Posted September 2, 2012 Share Posted September 2, 2012 Does anyone Have a schematic of a 91 Winnebago metal coach frame? Thanks Winnebago is still in business. Why don't you just ask them to send you one Linda S Quote Link to comment Share on other sites More sharing options...
futar Posted September 2, 2012 Author Share Posted September 2, 2012 Winnebago won't give you the right time of day, that's why I posted. Quote Link to comment Share on other sites More sharing options...
linda s Posted September 2, 2012 Share Posted September 2, 2012 Sorry but I didn't know that. I found some stuff from this site. This shows that they are not framed but are composite panels. Strength is all from the compression of the panels glued together. http://www.winnebagoind.com/service/wincd/1990/90wt319rb.pdf And this thread is where I got that and you can see one being pulled apart http://toyotamotorhome.org/forums/index.php?showtopic=2881&st=0&p=14318&hl=+winnebago%20+repairentry14318 Good description of construction in post #28 Hope this helps Linda S Quote Link to comment Share on other sites More sharing options...
futar Posted September 11, 2012 Author Share Posted September 11, 2012 Sorry but I didn't know that. I found some stuff from this site. This shows that they are not framed but are composite panels. Strength is all from the compression of the panels glued together http://www.winnebago...0/90wt319rb.pdf And this thread is where I got that and you can see one being pulled apart http://toyotamotorho...air Good description of construction in post #28 Hope this helps Linda S It says in there "aluminum" frame. Please do not post unless you have a schematic of the frame. Quote Link to comment Share on other sites More sharing options...
