rvman Posted June 6, 2012 Share Posted June 6, 2012 my ac dose not work and i want to remove it how do i do it and were do i get a vent for it. Quote Link to comment Share on other sites More sharing options...
Davidadro Posted June 6, 2012 Share Posted June 6, 2012 my ac dose not work and i want to remove it how do i do it and were do i get a vent for it. Once ya remove the AC, the hole left on top SHOULD be the same size as a regular 14x14 roof roof vent assembly, or skylight. Maybe ya could put a recessed lighting fixture in place as well, and cover the roof hole with a coverplate? it's your choice as to what you would like there, and a lot of options. Heres some You Tube advice that might help. This series can be some good basic help for a multitude of RV issues Good Luck, and peace! Quote Link to comment Share on other sites More sharing options...
Bunneys Posted June 8, 2012 Share Posted June 8, 2012 I just removed my A/C unit from my 89 Dolphin. I'm still working on the roof, but I have installed a fantastic fan in it's place. The hole is the standard 14" vent hole so you will have lots of choice as to what you install in it's place. To remove the unit you will need to remove the inside and outside covers. My unit had the heater option, so i had to unplug that, then undo the electrical connection, and remove 4 big bolts that bolts the top part with the inside part. once that is out you have to use something to lift up on the A/C unit, when it has some tension on it I moved back inside and there is sticky foam gasket stuck to both the ac unit and the top of your roof, just slowly separate form your roof, working in the RV through the 14" vent hole. If your not going to be selling the unit ( Mine was working, so I put an ad in Craigslist for $300 and it was sold in two days for $200...) you can just cut the gasket with a sharp knife. Here is a picture of the hole just after the unit was removed.. it is a little distorted because I did not know the foam gasket was there and it pulled the aluminum skin of the roof a wee bit when lifting up... and one of the unit off... It is not too hard... Good luck with the job! Andrew. Quote Link to comment Share on other sites More sharing options...
Bob C Posted June 9, 2012 Share Posted June 9, 2012 We are taking our first big trip in September after I retire. I may remove the AC if it turns out that it does not get used. I am lucky because I built the swing set in the back yard withintention of using it for lifting by using a chain hoist. I was told that it is pretty easy to remove the units if you have a means to lift it off. Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted June 9, 2012 Share Posted June 9, 2012 never removed an air conditioner, but to work on the roof vents i laid two 8' 2X4's across the top and a piece of plywood across that to climb on. personally even though i'm only 150 lbs i don't trust tbs roof to climb on. Quote Link to comment Share on other sites More sharing options...
rvman Posted June 9, 2012 Author Share Posted June 9, 2012 thanks we have a tractor and we can put it in its bucket. Quote Link to comment Share on other sites More sharing options...
outside Posted June 11, 2012 Share Posted June 11, 2012 Just removed my a/c unit and installed a vent. Pretty easy task and happy to lose the weight and gain the headroom! My old unit is in good working condition and for sale in Portland, OR if anyone interested. Quote Link to comment Share on other sites More sharing options...
waiter Posted June 12, 2012 Share Posted June 12, 2012 We're sitting in Cherry Hill park in Washington DC (Very nice by the way). Our 5000 btu Window unit has been humming along for 3 days. it was 93 today with high humidity, and muggy at night. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
84TOYRV Posted June 12, 2012 Share Posted June 12, 2012 And I'm sitting in my toyhome in Minnesota, dressed in layers, tryin to stay warm. Ha ha! Quote Link to comment Share on other sites More sharing options...
