dolphinguy Posted February 13, 2012 Share Posted February 13, 2012 just figured out with some great help from here that i need a 1979 toy dolphin battery isolator. not having much luck locating one any ideas?? thank you larry Quote Link to comment Share on other sites More sharing options...
Derek up North Posted February 13, 2012 Share Posted February 13, 2012 There is no such thing as a '1979 Dolphin battery isolator'. Try looking for an 'RV battery isolator'. Quote Link to comment Share on other sites More sharing options...
waiter Posted February 13, 2012 Share Posted February 13, 2012 Google "RV Battery Isolator" I would consider getting one of the inexpensive ones that look like a small can. These are 1/2 to 1/3 the price of the electronic ones. Check out Tweetys John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 13, 2012 Share Posted February 13, 2012 I think you said you had a solid state isolator if so---most auto parts stores will have them a 70 amp unit is fine. What you need to do before you go looking is count the number of terminals there will be 3 larger ones and maybe one small one if the small one is wired you will need to use a 4 terminal isolator. If it is not wired all you need is the 3 terminal unit or for that matter the 4 terminal and don't worry about the 4th wire if that's all they have. If you have a relay type they should have that also make sure it is a Continuous duty solenoid! They look like a starter solenoid but they are not. The solid state isolators involved some rewiring of the alternator so to switch back to a relay you would have to change the wiring so either way replace what you got. Quote Link to comment Share on other sites More sharing options...
