johnbutch Posted December 22, 2010 Share Posted December 22, 2010 Finally getting around to replace fuel pump. Do I have to drop the fuel tank or are there other ways to access the pump? What do pumps cost, and where can I get one? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 22, 2010 Share Posted December 22, 2010 I'm afraid you'll be dropping the gas tank. But are you sure it needs replacing? Have you checked that it's getting 12v? And has a good ground? Quote Link to comment Share on other sites More sharing options...
Viking66 Posted December 24, 2010 Share Posted December 24, 2010 I just replaced mine 1985. It was $137.00, and $12.00 for the small strainer/filter, should be close to the price for yours. Check the wires on the fuel pump bracket for continuity, the positive wire on mine was bad! I would also check the pump while it is out of the tank to ensure the wiring on your rig is good all the way back to the pump. When you pull the tank, it needs to be moved towards the driveshaft, and then it will rotate down and out. Re-install in reverse. Quote Link to comment Share on other sites More sharing options...
johnbutch Posted January 6, 2011 Author Share Posted January 6, 2011 Thanks guys I'll check the power to the pump. Then pull the tank if necessary Quote Link to comment Share on other sites More sharing options...
