futar Posted October 14, 2010 Share Posted October 14, 2010 My five foot Norcold operates great on 110v. However, sometimes when I switch to gas after the fridge is off for a few hours, the igniter light is on before the gas is lit. When this happens, the gas won't work. If I try and switch to gas immediately after switching from electric, it works fine. If I leave the igniter switch on after a few hours it finally goes out and I can use the gas. Any ideas what is wrong? Quote Link to comment Share on other sites More sharing options...
Maineah Posted October 14, 2010 Share Posted October 14, 2010 Sounds like the board. Dinosaur boards, they may even have a check list for your unit. Quote Link to comment Share on other sites More sharing options...
Alvin Posted October 15, 2010 Share Posted October 15, 2010 I've seen problems with thermocouples. I would find the thermocouple, loosen the wires, make sure that you have clean connections and that no corrosion exists (brush the connections a bit) and re-tighten everything back into place. If this doesn't do it, you may have a bad board. It also may be possible that the thermocouple location needs to be adjusted. Quote Link to comment Share on other sites More sharing options...
