DanAatTheCape Posted September 2, 2010 Share Posted September 2, 2010 Anyone ever tried the "upside down" "trick" to get the plumbing on the ammonia circuit on an refrig to working better? As I understand, if One is not getting good cooling after verifying heat is present (electric and/or propane) the the assumption is that the ammonia circuit is not percolating and that as by inverting the unit for 12 hours followed by 12 hours upright before trying it again One can improve the functioning. Any reports? Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted September 5, 2010 Share Posted September 5, 2010 Might work sorta. Reality is if its not working very well then some of the chemical components have probably solidified. Once that happens its over. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted September 12, 2010 Author Share Posted September 12, 2010 Might work sorta. Reality is if its not working very well then some of the chemical components have probably solidified. Once that happens its over. can anyone explain what process is going on inside the cooling unit? I have read reference to some of the materials converting to solids - is there anyway to test for this beside just turning it on & measuring the temps in the refrig? Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted September 14, 2010 Share Posted September 14, 2010 can anyone explain what process is going on inside the cooling unit? I have read reference to some of the materials converting to solids - is there anyway to test for this beside just turning it on & measuring the temps in the refrig? Follow this link as it will explain better than I can http://www.rvrefrigeratorrepair.com/how_it_cools.html Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted September 18, 2010 Author Share Posted September 18, 2010 Follow this link as it will explain better than I can http://www.rvrefrige...w_it_cools.html I put a new one in. Anyone want any dometic RM2410 parts? Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted September 18, 2010 Share Posted September 18, 2010 I put a new one in. Anyone want any dometic RM2410 parts? I'm looking for the little tray that fits into the opening on the right side of the bottom rack. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted September 20, 2010 Author Share Posted September 20, 2010 I'm looking for the little tray that fits into the opening on the right side of the bottom rack. not sure what you are referring too - are you inside the food compartment and not in the door racks? Quote Link to comment Share on other sites More sharing options...
