kim Posted June 13, 2010 Share Posted June 13, 2010 We just purchased a 1986 Toyota Conquest. We drove it home from Houston and it did great. However, it is now stuck in overdrive. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 13, 2010 Share Posted June 13, 2010 automatic? Quote Link to comment Share on other sites More sharing options...
86rader Posted June 18, 2010 Share Posted June 18, 2010 when you say stuck in OD, do you mean that it is literally stuck in OD and won't shift to a lower gear or do you mean the OD lockout function is not working? If it's the former, good luck! If it's the latter, I had the same problem with my sunrader. I thought it was the OD solenoid being stuck open, but, it wasn't. After changing it, I brought it to someone who actually knows what they are doing, hi tech transmission, in e. longmeadow mass. I HIGHLY recommend these guys. They dropped the valve body and discovered that the last one in there placed one of the little balls in the wrong passage. Total bill was a bit over 200 bucks. I was resigned to paying 500 or more going in. Quote Link to comment Share on other sites More sharing options...
