Bone Posted March 7, 2010 Share Posted March 7, 2010 Where might this be:) House battery that is. Large compartment on the driver side with nothing in it only some wires, Gen area? Batteries? Thanks, Tom H Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 7, 2010 Share Posted March 7, 2010 If it's large there might have been a generator at one point usually the battery has a fairly small compartment. There should be some #8 wires in there that go to the fuse panel and back to the front of the the MH to some type of isolator under the hood. The generator should have had armored cable of some and junction box. Quote Link to comment Share on other sites More sharing options...
dgerst Posted March 31, 2010 Share Posted March 31, 2010 My '85 Granville's coach battery is in the smaller compartment just in front of the left rear wheel. Where might this be:) House battery that is. Large compartment on the driver side with nothing in it only some wires, Gen area? Batteries? Thanks, Tom H Quote Link to comment Share on other sites More sharing options...
85mirage Posted March 31, 2010 Share Posted March 31, 2010 Maybe house battery is under the couch..If its recessed into floor look from below for battery sized sheetmetal box. most generator doors have a different type exterior door. An area on door that is unpainted screen/like mesh which allows for hot exhaust. If large compartment has that you can eliminate battery ever being there. do have picts posted? Quote Link to comment Share on other sites More sharing options...
Bone Posted April 1, 2010 Author Share Posted April 1, 2010 Yes, i did find the compartment on the drivewr side that would house the batt. No Battery in it, that is what threw me off. The large compartment is for a Gen. I just bought 2 120AH batt and put them in the large compartment as the previous owner had moved the wiring for the batt to that area and added wiring for 2 batt in parallel. Thanks for all the info, great board here. Tom H Quote Link to comment Share on other sites More sharing options...
