jml Posted February 3, 2010 Share Posted February 3, 2010 We have a "92 toy mh and the brake lights have stopped working, checked all the usual suspects, bulbs, fuse, switch which are all good and still no brake lights. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Tom W Posted February 3, 2010 Share Posted February 3, 2010 If you have 12v to the back, Maybe bad grounds in the light assembly's mine have rivets in the housings using a couple of hammers and re-preening them helps, or where they ground to the frame could be a problem. Quote Link to comment Share on other sites More sharing options...
85mirage Posted February 3, 2010 Share Posted February 3, 2010 That happend to my 85, it was a bad flasher unit. Cheap and easy fix. Now when i use the directionals it has a different sound/tempo than before.hope this helps Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted February 8, 2010 Share Posted February 8, 2010 Check to see if you have power to the socket, as Tom W said could be a bad ground. Could also be a bad brake light switch or bad wire at the brake pedal. Also power to the brake light circuit is obtained somewhere between the alternator and the under hood fuse box. It then runs directly to the under dash fuse box. Quote Link to comment Share on other sites More sharing options...
