dogre Posted August 6, 2009 Share Posted August 6, 2009 We want to check the fuse for the cab AC in our 1991 Toyota/Itasca Spirit. The owner's manual shows 3 fuse panels. We found 2 - one on the driver's side and one under the hood but cannot find the 3rd. The manual says it is on the passenger side under the dash but we couldn't find one there. Anyone know where to look? Thanks Quote Link to comment Share on other sites More sharing options...
Spirit Happy Posted August 7, 2009 Share Posted August 7, 2009 The inverter is under the couch. There are circuit breakers there for 110VAC which the AC uses. I dont know which one is the AC at the moment. Also. I had my AC go out unexpectedly on a trip. after I swerved (not recommended) to avoid an animal. Turned out all breakers inside were ok but no power anywhere on standard house sockets or the Airconditioning. The Generator runs. Turns out there is a breaker on the Kohler Generator that is very loose and easy to flip. The swerve did it. I reset it. All worked well after that. Hope that helps. Quote Link to comment Share on other sites More sharing options...
dogre Posted August 8, 2009 Author Share Posted August 8, 2009 The inverter is under the couch. There are circuit breakers there for 110VAC which the AC uses. I dont know which one is the AC at the moment. Also. I had my AC go out unexpectedly on a trip. after I swerved (not recommended) to avoid an animal. Turned out all breakers inside were ok but no power anywhere on standard house sockets or the Airconditioning. The Generator runs. Turns out there is a breaker on the Kohler Generator that is very loose and easy to flip. The swerve did it. I reset it.All worked well after that. Hope that helps. Thanks for the suggestion. I presently have the couch out (darned water leak in the filling tube) so I have been familiarizing myself with the hidden electronic goodies. We don't have A/C AC. We don't even have a generator. The fuse that we can't find is the one for the dashboard AC. Any tips on the whereabouts of the 12V AC fuse box that was supposed to be on the passenger seat kickpanel? I hope I don't have to remove the passenger seat up front. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted August 9, 2009 Share Posted August 9, 2009 The manuals say kick plate but Toyota put it way up and behind the glove box, so you have to pull all the screws that hold the glove box in and remove it to see the fuses. Should be two, in the upper right corner. Quote Link to comment Share on other sites More sharing options...
