yoyoman Posted June 15, 2009 Share Posted June 15, 2009 This is a pic of a 1979 Sunrader. I see the axle and it appears to stick out beyond the wheel and it has six lugnuts, which I believe are both signs that it is a good axle. Is this correct? Thanks!!! Quote Link to comment Share on other sites More sharing options...
Bodybagger Posted June 15, 2009 Share Posted June 15, 2009 I can't tell you if it's "good" or not (I mean it may have bad wheel bearings or other issues). But that is a 1 ton full floating axle. Quote Link to comment Share on other sites More sharing options...
wistoy Posted June 15, 2009 Share Posted June 15, 2009 yes the 6 lug axle vs the 5 lug axle, the 6 lug is the better axle. Quote Link to comment Share on other sites More sharing options...
yoyoman Posted June 15, 2009 Author Share Posted June 15, 2009 Thanks to both for the replies. Here's another one I'm looking at, which I thought was the same as the previous. It's a little harder to see, but any guesses from this small picture as to whether it's *good* or not? Thanks much! Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted June 15, 2009 Share Posted June 15, 2009 You have the good full floating axle. Quote Link to comment Share on other sites More sharing options...
yoyoman Posted June 18, 2009 Author Share Posted June 18, 2009 You have the good full floating axle. Thanks Gulfstream Greg -- Are you referring to the first or fourth post on this thread? thanks! Quote Link to comment Share on other sites More sharing options...
