hortonma Posted October 4, 2023 Share Posted October 4, 2023 Hi everyone, I posted about a month ago about my suspension causing damage to the vehicle. I fixed the part of the carb that had fallen off, but now the actual weber carb that is on there has wiggled loose and has created a massive vacuum leak while I was on a 1200-mile trip. I didn't have too much of a way to fix this, but now I am stationary and am going to rebuild the carb and replace the gasket. I will be using Loctite on the screws this time as well. I definitely need to do something about this ride because, even if i don't have any more issues with the carb from this, I am not enjoying the ride. Every little bump feels like a big pothole and it can make driving stressful. My question is: should I just go ahead and replace the leaf springs, add helper springs, and get new shocks, or could I just get away with helper springs and new shocks? Any combination of airbags, new shocks, new leaf springs, and helper springs I guess would be possible, but I just purchased this camper recently, so the funds are a little tight. Also, I have gathered that bilstein seems to be the way to go with shocks. Has anyone has good experience with other brands? Any specific product recommendations are welcomed Thanks! Quote Link to comment Share on other sites More sharing options...
gypsy Posted October 4, 2023 Share Posted October 4, 2023 I don't know the answer to some of your questions, but I owned a 1976 Chinook with old, worn-out shocks. Was finally able to replace with all custom...and it made a HUGE difference. Wish I had been able to do it earlier. I don't remember the cost, but around $500??? The front coil springs were ordered by a great Toyota mechanic so not sure where they came from. The rear were a private business in Grand Junction, Co. Don't know if they are still in business. Hope this helps a little. Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 4, 2023 Share Posted October 4, 2023 Your Weber problem could be the two piece adapter used to mate it to the Toyota manifold. They are known for problems with vacuum leaks. Quote Link to comment Share on other sites More sharing options...
