daveemac Posted January 7, 2023 Share Posted January 7, 2023 (edited) 1990 Odyssey. I'm looking forward to re-gearing to 4.56, trying to do it as cheaply as possible. There's an 8" 4.56 a couple hours away from me, taken from an unknown parts car. Do I have enough info (Toyota 8" 4.56 V6) to be sure it'll fit? Also, if it looks good, is it pretty safe to assume that it'll operate properly, or is it kind of a crapshoot? Thanks! https://www.facebook.com/marketplace/item/5475562242572726?hoisted=false&ref=saved&referral_code=null Edited January 7, 2023 by daveemac Quote Link to comment Share on other sites More sharing options...
linda s Posted January 7, 2023 Share Posted January 7, 2023 Might have been OK before they took the rear case off and covered the gears in wood chips. There are lots of differentials available in the Bay area. Check car-part.com You looking for a differential or carrier from a 89 to 93 4runner 4x4 with no ABS. Searching for the carrier will show the gear ratio so it's better. Linda S Quote Link to comment Share on other sites More sharing options...
daveemac Posted January 7, 2023 Author Share Posted January 7, 2023 Thanks Linda ! I've seen some off 4x4s, wasn't sure if they worked, thanks Quote Link to comment Share on other sites More sharing options...
