Scott iv Posted May 4, 2022 Share Posted May 4, 2022 Next maintenance item is replacing the seals and filters on my fuel injectors. Noticed when I did my head gasket last Fall that the injector seals were like most of the other o rings and seals I have been encountering; hard like plastic. At the time I did not have replacements and reassembled the vehicle as it was so I could continue to use it. I noticed last year (before and after head gasket job) and continuing this year a rough idle/low rpm at start when the engine is hot. Will do the injector maintenance and see whether it improves that situation. Quote Link to comment Share on other sites More sharing options...
