Remove Fresh water tank
I have a leak in the fresh water tank or the waterlines. Water tank and lines are under the couch. I am unable to get to the problem.
There has to be a way to get under there because your water pump is there too. Water pumps need to be replaced from time to time. How does this sofa make into a bed. Are there screws on the front panel beneath it that you can remove to lower the panel. Maybe some other Warrior owners here know how to get to it
Thanks for the response Linda. I think I have it figured out from looking at a few other posts and pictures here on the site. The sofa is a jackknife style sofa/bed. I don't think it will be that hard to remove, which will give me access to the fresh water tank, water lines and pump, plus allow me to remove the wet carpet and dry it out. This site is fantastic!!
BTW, I just recently pulled and repaired the black and the grey holding tanks (1990 Winnebago warrior). Grommets had to be replaced on both. I didn't take any pictures as I was not aware of this site yet. But if anyone out there has questions, I can probably help.
Retired GI
 Share
