kathleen Posted August 2, 2008 Share Posted August 2, 2008 My 88 Dolphin bathroom faucet is leaking and the culprit is the gasket in the hose from the tank that connects to the faucet. I cannot find this gasket anywhere. It is gray and like a washer but has an extended area that is thinner and fits into the hose. The RV places have all said that I should change out to compression hoses, but I'd rather just replace the gasket. Does anyone know where I can find this part? Thank you! Quote Link to comment Share on other sites More sharing options...
futar Posted August 2, 2008 Share Posted August 2, 2008 The only ones that I have seen use cone washers like the one attached. They have a metal retaining snap ring behind them. They're used a lot for plastic piping. They usually last a long time and will leak if they're pinched or not installed straight. Have you tried tightening it? Is the old one cracked? Take a picture or make a drawing with the posting so we can help you. Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 2, 2008 Share Posted August 2, 2008 Try a hardware store I bought a household fixture for mine as a replacement and it fit just fine so it seems that they should have what you need. Quote Link to comment Share on other sites More sharing options...
kathleen Posted August 3, 2008 Author Share Posted August 3, 2008 Thanks for responding. I've added 2 photos from my outdated camera of the gasket. Its outside dimensions is 3/4" and inside is 1/2". It is 1/4" deep with the top 1/8" being 1/8" deep and the bottom 1/8" being less than 1/16" deep. So the gasket is like a thick washer on top of a very thin vertical washer/gasket. Thanks for your help on this. I am going on vacation and won't be back on email until the 8th so thank you in advance and I look forward to hearing from you. Kathleen Quote Link to comment Share on other sites More sharing options...
futar Posted August 6, 2008 Share Posted August 6, 2008 It's hard to see what kind of a fitting they went in to. Beats me from the pics. Maineah's recommendation is a good idea. I replaced some of my faucets with "gooseneck" type bathroom faucet. Their much easier to get hands and containers under. Quote Link to comment Share on other sites More sharing options...
