cucklorde666 Posted October 6, 2021 Share Posted October 6, 2021 So i take it that there might be a problem with my converter? Also in terms of rear view camera for backing it on up.... what do yall recommend? thanks again. Quote Link to comment Share on other sites More sharing options...
WME Posted October 6, 2021 Share Posted October 6, 2021 Roof AC only runs if plugged into shore power, generator is running or you have a big as*ed inverter and even bigger battery hooked up to it. Check your power center. Normally there 3 circuit breakers. A 30 amp main and 2 14 amp sub breakers. The AC gets one breaker and the rest of the AC outlets the other. Quote Link to comment Share on other sites More sharing options...
