moalaska Posted September 12, 2019 Share Posted September 12, 2019 Is it normal for the toyhome manufacturers to put a larger fuel tank in and not do anything to adjust the fuel sender to be accurate? I'm pretty sure my tank is bigger on my 78', it always reads empty way before I run out of gas, like super way before, but reads full accurately. Quote Link to comment Share on other sites More sharing options...
linda s Posted September 12, 2019 Share Posted September 12, 2019 I have a 17 gallon tank. Most I've ever been able to put in it is about 14 gallons and that's after driving on empty for a while. Almost no manufacturers put in larger tanks. The very large reserve is a Toyota thing Linda S Quote Link to comment Share on other sites More sharing options...
BobBeery Posted September 13, 2019 Share Posted September 13, 2019 My 94 Warrior also is 17 gal. Part of the bottom of the tank has been pushed up a little which may reduce capacity but I think by less than half a gallon. I did manage to put in 15.7 gal once this year. I drove until the needle was almost below the E mark and then after the needle quit moving another 15 miles or so before filling. I based my driving on knowing my usual mileage times 16 and rounded down just a bit in case I was below average. Got away with it. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted September 13, 2019 Share Posted September 13, 2019 Some time between 1983 and 1986 (perhaps with the introduction of the FF axle, 137" WB), fuel tank changed from 16 to 17 gallons. Quote Link to comment Share on other sites More sharing options...
Scott ATX Posted February 20, 2023 Share Posted February 20, 2023 Does anyone have any experience with adding an additional tank to these motorhomes? I have a 1990 321RB Warrier with a 3.0L V6. Thanks! Scott Quote Link to comment Share on other sites More sharing options...
