Patty Posted August 22, 2018 Share Posted August 22, 2018 Hi, I am a newbie to this group. I just bought av1983 dolphin. I would like to replace the element on the hotbwater heater, but i can't remove it. It seems to be rusted in place. I did get the petcock to open. Can I put pressure on it to break it loose? (Pressure means a 72 year old woman And a big set of vise grips!) Quote Link to comment Share on other sites More sharing options...
linda s Posted August 22, 2018 Share Posted August 22, 2018 You need to buy a new water heater. A propane heating element that is rusted that badly will probably just break off not break loose. Better to be safe than sorry. Linda S Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 23, 2018 Share Posted August 23, 2018 Some had add on electric elements is that what you are talking about? Or the propane control? Unless you know exactly what you are doing it's best to leave the propane to the pros and if that's the case then linda nailed it, replacement is most likely the answer. Quote Link to comment Share on other sites More sharing options...
