Yostfmx Posted April 23, 2008 Share Posted April 23, 2008 So what the deal with air bags? Both of mine don't work, don't know why? How do you use them? Why do you have to use them if you have leaf springs? Can I run them with no air in them/not working? How does this come in to play with using 5 lug? I know nothing about them or how they work or what to look for to fix. Quote Link to comment Share on other sites More sharing options...
WME Posted April 23, 2008 Share Posted April 23, 2008 Hook up to an aircompressor set to about 40psi. Get a spray bottle of soapy water and start looking for lleaks. 70% of the time the bags are OK and its the lines or valves that are bad. Whe you get your "transformer Toy" finished check how it sits loaded. Level or a bit tail high and you won't need airbags. If its butt is draging then you need stiffer springs or airbags to make it sit level. Quote Link to comment Share on other sites More sharing options...
