pine_cone_express Posted July 29, 2017 Share Posted July 29, 2017 Hi, I'm wanting to upgrade all of the exterior running lights to led. I have a 1990 Winnebago Warrior. I'd like a solution that involves zero modification ie. uses same mounting holes. Any suggestions? I'm looking at these. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
markwilliam1 Posted July 29, 2017 Share Posted July 29, 2017 Nice looking lights pine. Dont know if the holes will be the same or not. I replaced all my running lights with 2 bulb incandescents last year. I had to drill 1 hole for each fixture as they didn't line up. Some rigs don't give you much extra wire behind the old lights so rewiring can be difficult. My suggestion is to completely seal the holes where the wires come out and the screw holes with butyl tape. Very important to prevent future leaks! The price for leds seems to be coming down. I couldn't afford them last year. Good Luck! Quote Link to comment Share on other sites More sharing options...
hunkaman Posted August 4, 2017 Share Posted August 4, 2017 I have a 92 warrior, replaced all clearance lights with incandescent because led's were 3x as much money. but, I found a website for led's, I believe it is LEDLIGHTS.COM, and their led clearance lights were under $5.00 each. good luck. joe from dover. Quote Link to comment Share on other sites More sharing options...
hunkaman Posted August 4, 2017 Share Posted August 4, 2017 I see you are in Louisville, ky. I will be going there for the national jugband music jubilee in September. Quote Link to comment Share on other sites More sharing options...
