Cody72 Posted May 26, 2017 Share Posted May 26, 2017 (edited) Finally got my shower project done, the back wall was wavy from what I thought was a leak from the shower, turned out to be a screw through the seam of the top and sides. Much brighter than wallpaper now anyway and looks sparkly clean. Edited May 27, 2017 by Cody72 Bad spelling Quote Link to comment Share on other sites More sharing options...
KGordon Posted May 27, 2017 Share Posted May 27, 2017 Pictures? Quote Link to comment Share on other sites More sharing options...
DanDanLongDan Posted May 30, 2017 Share Posted May 30, 2017 What materials did you end up using? I'm just about to do the same type of repair/upgrade. Quote Link to comment Share on other sites More sharing options...
hunkaman Posted May 31, 2017 Share Posted May 31, 2017 many have used FRP. commonly found at the big box stores. lowes, home depot. inside corner and outside "cap" or trim mouldings are available. applied with adhesive. joe from dover. Quote Link to comment Share on other sites More sharing options...
Cody72 Posted May 31, 2017 Author Share Posted May 31, 2017 Exactly right Joe! Quote Link to comment Share on other sites More sharing options...
OregonSteve Posted July 9, 2020 Share Posted July 9, 2020 Hi- I just got an '86 Dolphin and the whole back wall (it's the bathroom) needs to be replaced. I'm not sure if I do it from the inside or the outside... Any pointers? Thanx OregonSteve Quote Link to comment Share on other sites More sharing options...
Bryan Zee Posted December 11, 2023 Share Posted December 11, 2023 Hi. I'm rebuilding a 1989 Dolphin and wondering if anyone makes a shower stall that would fit. I've thought about the FRP but would prefer something more solid. I'm also replacing the toilet if anyone has a recommendation. Quote Link to comment Share on other sites More sharing options...
Marianne Posted April 16 Share Posted April 16 Hello, all. I have a 1986 Nova Star with the fiberglass shell. If I use FRP, I am creating a second vapor barrier, correct? Does anyone have suggestions for other bathroom wall materisls to avoid moisture and mould growth, especially from condensation inside the wall? Is this even something I should worry about? Quote Link to comment Share on other sites More sharing options...
MaineJed Posted April 17 Share Posted April 17 6 hours ago, Marianne said: Hello, all. I have a 1986 Nova Star with the fiberglass shell. If I use FRP, I am creating a second vapor barrier, correct? Does anyone have suggestions for other bathroom wall materisls to avoid moisture and mould growth, especially from condensation inside the wall? Is this even something I should worry about? No don’t worry about it. Quote Link to comment Share on other sites More sharing options...
