Showing results for tags 'gasket'.
Just finished a nice little trip to Lake of the Ozarks SP over a long weekend. Great weather, nice scenery, and tons of surprisingly tame, white-tailed deer, right up around the Warrior for most of our stay. Brought our e-bikes along, per usual, and the wife and I had a great time buzzing around the area. Unfortunately, heading out of the park and down the main park entry road on our way home, a loud crash was heard overhead, then a few pieces of debris rained down on the hood. The large 59x12" cabover window is gone, as you can seeāmost of the glass ended up inside the window curtain and on the mattress. Not sure if a falling branch struck the window or if a large bird impacted or what - ?! We drove home just fine but kept it under 55mph. First time that's happened to us in our eight years of ownership. So the question is whether to try and replace the glass... or to block off that unlucky window opening completely. The large rubber window seal is in pretty good shape, it appears, but I know these Class C cabover windows tend to be problematic, even from the factory. I'm reading through the forum posts on the subject, but feel free to chime in here if you have any thoughts/suggestions. Thanks!
Hi - hoping someone can help me out here. I'm looking to find the correct window gasketing for the exterior of my 1986 Escaper. Mine is shrinking/cracking, which seems to be a common problem. Below I've included a side view of the gasket that's been pulled out of the window. Thanks in advance! Toby
ok, so thanks to WME I have the correct nuts to reclamp down the exhaust manifold to the downpipe (not the block) So again block, manifold, then this 3 bolt flange thing that goes to down. pipe and then exhaust... I picked up a spare gasket, its like a coiled light blue crushable circle gasket common for these. here is my question... I am assuming there was a gasket pressed in before; do I need to dig that one out and use new one or can i just tighten it down and save this new one as a spare?
nearly all of the gaskets on the exterior of my rig are in terrible condition. where do I go to find fresh rubbers? I think the windows were made by topo chico. if that helps. Edited 3/10/18, I guess topo chico is bottled water. I don't know why I was thinking that they did windows. turns out there are no makers markings on the coach window. I intend to add pictures but my file size is too large for here. I will adjust and attempt to resubmit.
Does anyone have a recommendations for the Buffalo area? I've got the 1984 22R 4 speed manual mini RV with pop up top. Started leaking oil badly today, and it's going to be a big job. Just curious if anyone has any recommendations in this part of NY or the Erie part of Pennsylvania. Thanks
- timing chain
- oil
