prasi00
Toyota Odyssey VIN number
6 posts in this topic
Hello, i own 1987 oddysey which was registered for many years in UK. I exported it to Bulgaria last year and want to register it here but i am bing refused as the local authorities cannot find a vin number stamped on the frame. The only vins I can find are the stamp on the dashboard and a sticker on the door. Nothing on the frame though. Is there a vin stamped somewhere else  on the chassis ?
Really hope there is as otherwise i am stuck with an expensive stationary caravan!
Edited by prasi00
Spelling mistake
My rig is much older than yours (1978). My chassis serial number is stamped on the left front frame rail just forward of the lower A-arm. You may need a wire brush to find it.
Thanks Fred. Is this the left when you are facing the camper or when you are sitting inside?
Drivers side. Left if sitting inside. The numbers may be covered with rust or road dirt.
There is a big spread between our mfg years. Hopefully Toyota remained consistent with their ID placement.
Hold fingers. Setting up a day next week for crawling under the toy with a flashlight and wire brush
It should be on the outside of the frame rail, on the large flat surface.
