nuggets Posted March 23, 2005 Share Posted March 23, 2005 HI WHAT SIZE CAN I USE TO RUN THE OVER HEAD AIR >> WILL A 1850 SURGE RUN IT >> I NEED ONE THATS SMALL ENOUGH TO GO IN THE SIDE BOX >> IT HAD A 2500 FIRST GO AROUND >> ANY AND ALL HELP THANK YOU >> PLAYING WITH MY TOY IN MS NUGGETS . Quote Link to comment Share on other sites More sharing options...
WME Posted March 23, 2005 Share Posted March 23, 2005 How many BTU's is the overhead A/C Quote Link to comment Share on other sites More sharing options...
nuggets Posted March 23, 2005 Author Share Posted March 23, 2005 HI OVRHEAD AIR IS 13.500 THANKS NUGGETS Quote Link to comment Share on other sites More sharing options...
WME Posted March 25, 2005 Share Posted March 25, 2005 On a hot day my Onan 2800 micro lite will just start my 13,500 BTU roof air. I have to turn off the A/C compressor (raise the temp on the thermostat) to run the Microwave. Most early Toys came with a Koler or Onan 3000 watt generator, the later ones have the Onan 2800 watt Micro lite. IF you change the roof air to a 7000 btu unit the 1850 generator will run it OK. A lot of folks go this route because most of the time a new A/C and 2kw generator is cheaper that a Onan RV generator. Or you can but a 3kw industrial unit for $500 and mount it on the bumper. But they are nosier than the RV units Quote Link to comment Share on other sites More sharing options...
nuggets Posted March 25, 2005 Author Share Posted March 25, 2005 THANK YOU SO MUCH FOR THE INFO >> I APRECIATE YOU TAKING THE TIME TO HELP >> NUGGETS IN MS . Quote Link to comment Share on other sites More sharing options...
