Guest hiinthesky Posted February 19, 2011 Share Posted February 19, 2011 (edited) I am searching for a spare dually rim for my 1987 Sun Land Express. 14 inch rim. The axle is a six bolt - full floating. I need to know what the bolt pattern, size is. I think its maybe 7.75. Does this sound right? Also is there a better solution to having two spares one six bolt for the back and one five bolt for the front. I have read other posts where people are talking about some sort of an adapter. What is that all that about? Had a good time at the rally this year in Quartzsite. Enjoyed meeting everyone that attended. I learned a great deal as I am a newbie just bought the RV about three weeks before the rally. That Tika really knows how to throw a rally. Bruce Kenney Topeka ,kansas Edited February 19, 2011 by hiinthesky Quote Link to comment Share on other sites More sharing options...
Derek up North Posted February 19, 2011 Share Posted February 19, 2011 Have you looked on www.car-part.com? Check '87>, Toyota pickup, wheels. I think the wheel is 7.25" PCD/BCD. The adapter attaches to the 5 stud front hub. It has 6 studs to which you can attach a 6 hole wheel. Custom & Commercial 14547 HAWTHORNE AVE FONTANA, CA 92335-2508 Phone: 909-357-3505 Quote Link to comment Share on other sites More sharing options...
waiter Posted February 19, 2011 Share Posted February 19, 2011 I'm looking for a dullie wheel also. the 7.25 seems correct. The bolt pattern are much larger than normal 14" I seen a month or so ago someone had 6 for sale for around $150. If I find it again, I may purchase. I figure if I can get a wheel for about $50 with shipping, that's probably a good price. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted February 19, 2011 Share Posted February 19, 2011 They make a spare carrier for the square rear bumpers. The front under in the norm position and the dual on the carrier. Some say don't worry about the rear but I disagree. We got a nail in a rear tire sidewall, non repairable on a Saturday eve. If I had not had a spare I would have been stuck as I had 200 miles to drive the next day (Sunday) to get home. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted February 19, 2011 Share Posted February 19, 2011 Here's an innocent question that maybe someone with experience can answer. Is there any problem using the standard carrier/hoist designed for a 5 lug rim with a 6 lug rim? I don't expect so, but just to confirm. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted February 19, 2011 Share Posted February 19, 2011 Here's an innocent question that maybe someone with experience can answer. Is there any problem using the standard carrier/hoist designed for a 5 lug rim with a 6 lug rim? I don't expect so, but just to confirm. It might not work as the hole in the center of the 1 ton wheel is larger. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted February 19, 2011 Share Posted February 19, 2011 So the wheel is held by something that uses the center hole. So I assume whatever it is could be modified to be longer without too much trouble. But something to be remembered by someone doing the change. Quote Link to comment Share on other sites More sharing options...
WME Posted February 19, 2011 Share Posted February 19, 2011 You need to modify the 5 bolt carrier. I just welded on a piece of 1" sq tubing with a 1/2" bolt, threaded through and welded on each end, 7.25" apart Quote Link to comment Share on other sites More sharing options...
