Ruby Posted November 15, 2019 Share Posted November 15, 2019 Hello, I have a 1983 Toyota Huntsman (20 ft) with the original 5 lug nut axle and I am looking to get it replaced. I am calling around scrap yards to find a replacement and I just want to make sure I know what to ask for. What I've gathered from talking to a couple mechanics is that I need a full floating axle from a 3/4 or 1 ton (1 ton better) Toyota with a 4/10 gear ratio. Also need the deferential and the drive shaft. Correct? Any other specification I should ask for? Thanks! -Ruby Quote Link to comment Share on other sites More sharing options...
AtlantaCamper Posted November 15, 2019 Share Posted November 15, 2019 33 minutes ago, Ruby said: I need a full floating axle from a 3/4 or 1 ton (1 ton better) Toyota Where are you located? I don't suppose you are any where near Georgia? Cause this one is available: https://atlanta.craigslist.org/atl/pts/d/lithia-springs-1987-toyota-rv-parting/6984285844.html You can find a decent used 4.1 3rd member pretty easily if your axle doesn't come with one. This is the one available at that link above and will give you an idea of all of the "extras" that ideally would come with a used axle (this one has the drive shaft available too and I'm pretty sure it's a 4.1): Quote Link to comment Share on other sites More sharing options...
Ruby Posted November 15, 2019 Author Share Posted November 15, 2019 In Oregon, Thanks though! Quote Link to comment Share on other sites More sharing options...
linda s Posted November 15, 2019 Share Posted November 15, 2019 The only thing you need to ask for is a 6 lug dually axle. Don't think you need a different driveshaft. Try these guys. They might have the part and I'm pretty sure someone from here had them install their axle in the past https://www.alltoyotaparts.com/ Buckley Wa so at least not all the way across country Linda S Quote Link to comment Share on other sites More sharing options...
JohnVandKerrinG Posted November 30, 2019 Share Posted November 30, 2019 We just ( driving back to Battle Ground, WA as I post this) picked up one in Nanaimo, BC at South Island Imports for our 1983 New Horizon. Also picked up a couple of cab seats 🤗. Our mechanic also found a couple somewhere in Alaska. They are out there! Good luck! Quote Link to comment Share on other sites More sharing options...
