DuallyXrunner Posted June 21, 2016 Share Posted June 21, 2016 Hi, I have a 2008 X runner thats a salvage that I'm bringing back to life, and will be used as a utility vehicle. I aquired a 6 lug FF rear end from a Toyota camper and have a couple questions. 1. 2 of the wheel studs are broken. Does anyone have a part number, a cross reference, anything? This also refers to brake pads. I tried autozone/orielly, etc and no luck. 2. Could you remove the adapter and put a single wheel on? i.e. Install studs from the inside out? Is that bolt pattern the same 6.25"? The X runner has a much stronger motor and a 6 speed trans, so while the 4.10 is welcome (I'll be using it for towing random stuff), the standard 14" tires are going to be pretty small. Quote Link to comment Share on other sites More sharing options...
Dolphinite no longer here Posted June 21, 2016 Share Posted June 21, 2016 What is an "X" runner? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 21, 2016 Share Posted June 21, 2016 http://www.caranddriver.com/news/toyota-tacoma-x-runner-auto-shows Quote Link to comment Share on other sites More sharing options...
zero Posted June 21, 2016 Share Posted June 21, 2016 11 hours ago, DuallyXrunner said: Hi, I have a 2008 X runner thats a salvage that I'm bringing back to life, and will be used as a utility vehicle. I aquired a 6 lug FF rear end from a Toyota camper and have a couple questions. 1. 2 of the wheel studs are broken. Does anyone have a part number, a cross reference, anything? This also refers to brake pads. I tried autozone/orielly, etc and no luck. 2. Could you remove the adapter and put a single wheel on? i.e. Install studs from the inside out? Is that bolt pattern the same 6.25"? The X runner has a much stronger motor and a 6 speed trans, so while the 4.10 is welcome (I'll be using it for towing random stuff), the standard 14" tires are going to be pretty small. Bolt pattern for a full-floater is 6 x 7.25". Nothing else like it except on some old Dodge, IH, Ford, trucks with 16-17" wheels and split-rims, the Korean "Humvees" also with split-rims, and one version of a Dyna school bus. Dorman sells new wheel studs. Easy to get or order at any auto parts store. Probably Dorman part # 610-339, but double-check. Quote Link to comment Share on other sites More sharing options...
DuallyXrunner Posted June 25, 2016 Author Share Posted June 25, 2016 After posting that, I think I found my answer. I'm going to try and order custom drilled wheel blanks. Don't seem outrageously priced, look good, and will give me the taller tire I need for my drivetrain. No won't be dually, but the full float axle is still the big plus. As for the wheel studs...Thankyou very much! Quote Link to comment Share on other sites More sharing options...
