steeve Posted July 17, 2015 Share Posted July 17, 2015 This is upgrade for my motorhome: new wfco 9855 converter ctek d250s dual battery charger with vsr and mppt controller 2 batteries crown cr 235 2000 watts samlex pure sine inverter aluminium cargo box in the rear reinforce the frame in the rear fantastic fan forward -reverse with thermostat 7 new tire continental vanco 2 naxa tv 19 inch with dvd player brand new Toyota engine (5000 miles) repack bearing ,change all the brakes ,change wire cap and pugs water pumps , all the fluids, new exhaust after the catalytic converter clean injector Quote Link to comment Share on other sites More sharing options...
Nam Posted July 17, 2015 Share Posted July 17, 2015 Assuming this is the 23ft version; where do you mount your spare tire? Quote Link to comment Share on other sites More sharing options...
zero Posted July 17, 2015 Share Posted July 17, 2015 This is upgrade for my motorhome: new wfco 9855 converter ctek d250s dual battery charger with vsr and mppt controller 2 batteries crown cr 235 2000 watts samlex pure sine inverter aluminium cargo box in the rear reinforce the frame in the rear fantastic fan forward -reverse with thermostat 7 new tire continental vanco 2 naxa tv 19 inch with dvd player brand new Toyota engine (5000 miles) repack bearing ,change all the brakes ,change wire cap and pugs water pumps , all the fluids, new exhaust after the catalytic converter clean injector Sounds similar to my Minicruiser except I've got a 3000 watt so-called "pure sine wave" inverter (although I know it is not), no new engine, and our TV is 32'. We started out with a 19" but I got a new 32" LED-LEC with built in DVD player for $200 and went for it. My wife protested at first saying it was too big but now really likes it. Fits nicely on our "kitchen" table and stows easily in our closet. I wish I HAD put a new water pump in it before it left us dead on the higway when the fan literally came off with the bearing stub. It's new now - but cost us $2000 instead of $35. Quote Link to comment Share on other sites More sharing options...
steeve Posted July 17, 2015 Author Share Posted July 17, 2015 It's 21.5 ft and the spare tire is Under the rear motorhome. Quote Link to comment Share on other sites More sharing options...
donttreadonme Posted July 21, 2015 Share Posted July 21, 2015 How did you reinforce the frame in the rear? Quote Link to comment Share on other sites More sharing options...
steeve Posted July 22, 2015 Author Share Posted July 22, 2015 Put tubing Inside the c frame bolted with 8 grad hexagonal bolt and welded. Quote Link to comment Share on other sites More sharing options...
donttreadonme Posted July 22, 2015 Share Posted July 22, 2015 Do you have any pictures of how you accomplished this? Quote Link to comment Share on other sites More sharing options...
steeve Posted July 22, 2015 Author Share Posted July 22, 2015 Sorry i don't have pictures for that, a welder do the job for me. Quote Link to comment Share on other sites More sharing options...
Nam Posted July 31, 2015 Share Posted July 31, 2015 Hi Steeve, Would you mind snapping a pic under the motor home showing how the frame extension was done and where the spare tire was mounted. Mine is same as your but the spare tire has to be mounted in the back of the bumper, not under? Thanks, It's 21.5 ft and the spare tire is Under the rear motorhome. Quote Link to comment Share on other sites More sharing options...
