This is upgrade for my motorhome:
new wfco 9855 converter
ctek d250s dual battery charger with vsr and mppt controller
2 batteries crown cr 235
2000 watts samlex pure sine inverter
aluminium cargo box in the rear
reinforce the frame in the rear
fantastic fan forward -reverse with thermostat
7 new tire continental vanco 2
naxa tv 19 inch with dvd player
brand new Toyota engine (5000 miles)
repack bearing ,change all the brakes ,change wire cap and pugs
water pumps , all the fluids, new exhaust after the catalytic converter
clean injector
post-7380-0-67605900-1437097680_thumb.jp
post-7380-0-66608400-1437097736_thumb.jp
post-7380-0-92002700-1437097798_thumb.jp
Assuming this is the 23ft version; where do you mount your spare tire?
clean injector
Sounds similar to my Minicruiser except I've got a 3000 watt so-called "pure sine wave" inverter (although I know it is not), no new engine, and our TV is 32'. We started out with a 19" but I got a new 32" LED-LEC with built in DVD player for $200 and went for it. My wife protested at first saying it was too big but now really likes it. Fits nicely on our "kitchen" table and stows easily in our closet. I wish I HAD put a new water pump in it before it left us dead on the higway when the fan literally came off with the bearing stub. It's new now - but cost us $2000 instead of $35.
Hi Steeve,
Would you mind snapping a pic under the motor home showing how the frame extension was done and where the spare tire was mounted. Mine is same as your but the spare tire has to be mounted in the back of the bumper, not under?
Thanks,
It's 21.5 ft and the spare tire is Under the rear motorhome.
