At long last, after replacing my plugs, wires, distributer cap, ignition coil, and fuel filter, I have discovered the cause of my Dolphin failing under load and idleing rough; the Idle Air Control Valve. Unfortunately, this part has been a booger to find. Does anybody have one for sale or know where I can locate one? Obviously, salvage yards are a good option, and I've been to a number of them, just haven't found a 22re with the part still in it.
post-8343-0-63981300-1437066507_thumb.jp
post-8343-0-60498200-1437066508_thumb.jp
No, This is Ben. Currently NW OR, but if you have the part, and Gerald doesn't need it, I'll certainly take it.
  • 2 months later...
Hey Sojouner,
Did you have a case where the idle was high and then low and then the engine eventually died? That's what I'm dealing with now.
  • 1 month later...
FYI your picture is actually the AC Idle up control, not the Idle Air Control Valve
