Jake_Womack Posted June 30, 2015 Share Posted June 30, 2015 (edited) I pulled up the original carpet and found this sheet of 1/4" aluminum screwed to my subfloor. Is this stock? I'm in the middle of putting down a new vinyl floor. I'll have updated pics as I go. Edited June 30, 2015 by Jake_Womack Quote Link to comment Share on other sites More sharing options...
kgragert Posted June 30, 2015 Share Posted June 30, 2015 I have a '91 and it doesn't have the aluminum sub floor. It looks like someone added it on to strengthen the floor. Quote Link to comment Share on other sites More sharing options...
Jake_Womack Posted June 30, 2015 Author Share Posted June 30, 2015 I just find it odd that it was under the original carpet. The same carpet that is laid under all of my cabinets and appliances. Has anyone else ever seen this? I had to cut 1/4" plywood to fill in the gaps where the aluminum fell short. Quote Link to comment Share on other sites More sharing options...
kgragert Posted July 1, 2015 Share Posted July 1, 2015 The carpet in mine was laid before they installed the sofa frame or dinette . So it had to be cut around the edges of those when the carpet was removed. Quote Link to comment Share on other sites More sharing options...
jdfrost64 Posted July 2, 2015 Share Posted July 2, 2015 if it is the factory carpet it will be under the walls to. that's how they carpet rvs . they lay the floor and carpet it .then they build the rest of the coach. Quote Link to comment Share on other sites More sharing options...
jdfrost64 Posted July 2, 2015 Share Posted July 2, 2015 they probly screwed up floor when building rv and that's how they fixed it , I have seen them scab floors worse that that before. Quote Link to comment Share on other sites More sharing options...
