SanDiegoPaul Posted November 6, 2007 Share Posted November 6, 2007 By the shower in the far, back corner under the motorhome I found a water connection for a hose. What is it for? Are you not supposed to use the water pump water in the shower? Sorry, I don't have a clue... Quote Link to comment Share on other sites More sharing options...
85Seabreeze Posted November 7, 2007 Share Posted November 7, 2007 That is a direct hookup to fresh water, meaning you can use all the water you want without draining whats in your fresh water tank. Just remember that your gray water holding tank doesn't inrease in size when you are directly hooked up to water and so it'll fill up much quicker. It is great for showering though, you can stay in the shower until your hot water runs out, but you'll have to quietly spring a leak into the bushes with your gray water. Quote Link to comment Share on other sites More sharing options...
SanDiegoPaul Posted November 7, 2007 Author Share Posted November 7, 2007 That is a direct hookup to fresh water, meaning you can use all the water you want without draining whats in your fresh water tank. Just remember that your gray water holding tank doesn't inrease in size when you are directly hooked up to water and so it'll fill up much quicker. It is great for showering though, you can stay in the shower until your hot water runs out, but you'll have to quietly spring a leak into the bushes with your gray water. Thank you for that! Sure seems that on an old MH though, one would need to be careful. Wouldn't the pressure of a garden hose pop fittings and hoses that are used to a 12V pump? Quote Link to comment Share on other sites More sharing options...
picklebill Posted November 7, 2007 Share Posted November 7, 2007 Hi Paul - Hooking up to an external fresh water source should be no problem. I use a pressure regulator on the hose set to 45 PSI. The first time you do this though, turn the water supply on to pressurize the system, and then shut it off and check everything for any leaks. Also, the pressure in the system when hooked up to an external water supply should keep the pump from coming on. Bill Quote Link to comment Share on other sites More sharing options...
