notsobigkahuna Posted August 7, 2014 Share Posted August 7, 2014 I've started to get a mild grinding coming from the rear brakes. I've got an 89. Any advice on tracking down brake parts? Are they standard more or less for 1 ton pickup? Might as well do wheel cylinders, shoes, springs and drums while in there. Kahuna Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 7, 2014 Share Posted August 7, 2014 Toyota 1-Ton Dual Rear Wheel (there's also a 1-Ton Single Rear Wheel which is different). Inspect and repack the rear wheel bearings too. And since you'll be in the neighbourhood, check the rubber bushings at both ends of the leaf springs. They seem to suffer badly! Quote Link to comment Share on other sites More sharing options...
zero Posted August 7, 2014 Share Posted August 7, 2014 I've started to get a mild grinding coming from the rear brakes. I've got an 89. Any advice on tracking down brake parts? Are they standard more or less for 1 ton pickup? Might as well do wheel cylinders, shoes, springs and drums while in there. Kahuna I never had any problem getting the correct parts. Dirt cheap from Rock Auto. Just make sure you order for the 1 t on dually cab & chassis truck. One word of slight caution. For some reason - I've get to buy a brake hardware kit that comes with the correct anchor pins. I've kits from three different brands and all came with pins that were too short. Rear brake parts Shoes: 10” X 2 3/16 (254 mm X 56 mm) CENTRIC 11105230, CARLSON Part # A523, BENDIX Part # RS523, WAGNER Part # PAB523, NAPA TS523 Hold-down kit: BENDIX Part # H7215DP, RAYBESTOS Part # H171332, AUTOSPECIALTY / KELSEY-HAYES Part # HK2209, ACDELCO Part # 18K628, WAGNER Part # H17133, NAPA UP 2273 Wheel cylinder: 7/8” bore BENDIX Part # 33919, RAYBESTOS Part # WC37654, AMERICAN REMANUFACTURERS INC. Part # 78422707, ACDELCO Part # 18E244, WAGNER Part # WC110923, DORMAN Part # W37654, AUTOSPECIALTY / KELSEY-HAYES Part # W56707, NAPA ATM P9466 Outer wheel-axle-seal: 1.625” OD , 1.35” shaft size, .35” wide L & S AUTOMOTIVE PRODUCTS Part # 7113911, BECK/ARNLEY Part # 0523184, NATIONAL Part # 710076, TIMKEN Part # 710076, SKF Part # 13911, VICTOR REINZ Part # 66527, NAPA NOS 13911 Inner wheel seal: 3.35” OD, 2.4” shaft size, .31” thick. BECK/ARNLEY Part # 0522680, L & S AUTOMOTIVE PRODUCTS Part # 7124635 , PRECISION AUTOMOTIVE Part # 226285, NATIONAL Part # 226285, SKF Part # 24635, TIMKEN Part # 226285, NAPA ATM 2117203 , NAPA NOS 24635 Proper length hold-down pins: 2 1/8” NAPA UP 80706 Quote Link to comment Share on other sites More sharing options...
